FairweatherDave
My Suzuki has cooling flow, the same as normal. I have checked the impellor and it is fine. Most of the cooling water exits under water but you get a fine spray out of the two little holes on the leg, mainly at idle. So as far as I can see the engine cooling system is fine (I have used this outboard for ten years plus.) I gave the engine a bit of a thrash on Saturday to test how well it was running and maybe some slight fuel starvation occurred as the revs dropped suddenly after a while. The fuel side can be temperamental. However I felt the engine was hotter than I would like, my finger tips on the metal part under the fuel tank were one indicator, and there seemed a fair bit of white exhaust smoke. At the time I did not think "that's steam".
Since then I have run the engine in a bin and observed the normal cooling flow.
So I was thinking of using some rydlyme (I last cleaned the passages manually 3 years ago so I know how they can block up).
But the crunch question is what symptoms should I be looking for so I don't knacker the engine if it is getting too hot?
