About Time
I have a sudden issue with my sidepower SE 60 thruster which I hope you can help with.
When I push the two ON keys on the control panels the light comes on but once I use the joystick I hear a click from the relay and an 'initial' starting noise from the thruster (0.5 sec) and then the light on the control panels goes out (OFF). I went in the water as I thought something had entered the thruster tube blocking the propeller but nothing down there and the propeller moves freely.
The thruster is connected to my starter battery and the two engines fire up easily.
Performed some tests...
I can start the engines - let them idle for a while and then sometimes I can use the thruster as usual.... or if I join my starter and service battery together (emergency start) then I can make the thruster work too. Seems like the thruster all of a sudden needs more power ......
Therefore I went along for a new starter battery as I thought my old one was dying but sadly no change.....
I am now wondering if the thruster relay (that clicks) can be worn creating more resistance and therefore now requires a higher amp to work... or maybe it does not work like this
Anything else to study before I move on with a new relay and may find this waste of money too....
Thanks to a great forum and all the wise boaters here.
