rubberduck
What would be the pros & cons of each ?
I'll tell you how well my new gyro works in a few days time
I believe Bart's fins are leccy powered, so easier to route, and more compact for the installation.Gyro. It will be cheaper, you dont need to bolt a PTO and hydraulic pump on to one of your engines and/or gennie, you wont have to rip your boat apart to run hydraulic hoses to the actuators, you wont have to drill big holes in your boat, you wont kill swimmers with the flappy things, you wont wipe a flappy thing off when you park next to a concrete quay and you wont lose any speed. Apart from that, fins are great
Seakeeper 5 or 6 sounds about right. Should cost you £45-55k inc fitting w/o VAT
Ermm, no, it isn't...apparently this is allowed in Italy and nobody cares about it...
You might try to search the forum a bit, if you wish to spend a whole night reading about this subject rather than sleeping...What would be the pros & cons of each ?
...but in a sense, that's the reason why nobody around there with an Itama or similar care about it!![]()
any more news available from the Quick Marine gyro's ?
If going for fins these are perfect for retro fit to this size of boat
http://humphree.com/how-it-works/fin/
