Capt_Scarlet
I have a Yanmar 2GM20 that suffered from poor starting last season. It would only fire on 1 cylinder when cold.
I removed the cylinder head last weekend, and discovered heavy pitting in the head and piston of one cylinder, and the piston could be wobbled in the bore by about 0.5mm - the other cylinder was fine. Also, the pitted one has far greater carbon deposits on it.
I reckon I need a new piston and rings in the duff cylinder, and probably new valves.
My questions are:
a) What was the likely cause?
b) Am I likely to get away with just a piston and ring change, or is a rebore required (no obvious scoring seen).
Thank you.
My questions are:
Thank you.
