Shurflo pro blaster not sucking very much any more
TradewindSailor
26 Jan 2007
New Zealand
The problem is that it takes a lot to suck air --- compressibility and small volumes. Most likely problems:
Dirt in the diaphragm valves .... doesn't take much.
The seal between the body halves is damaged .... try immersing the casing in fresh water and then operate it .... but don't get the pump motor or electrical connection in the water
Air being sucked in before the pump
partially blocked feed .... filter / hose / connections
Good luck ... they are good pumps ....
