surekandoo
I've bought a s/h Loos rigging tension gauge to set my rigging up this season
My boat has a fractional rig,. Upper shrouds are parallel with the mast i.e. not swept back, and there are two sets of lowers, one set going forward, and one set swept back. The uppers are fastened through the deck to the main bulkhead, the lowers are fastened through the deck and connected to rods which themselves are connected to the backs of the internal seating down each side of the main cabin. The forward lowers are just connected through deck with no additional internal support structure.
The port forward lower ONLY is showing early signs of pulling through the deck although in the current tension doesn't seem excessive. This has happened over winter while the boat has been ashore, so may have had a "clonk". Who knows. Anyway I will " plate" the anchorage internally and reset the tension.
How do I set the rig up?
I understand about getting the mast vertical from side to side using the main halyard, and also using it to set the mast rake.
What I don't understand is setting the relative tension of the forward & aft lower shrouds.
Can anyone help please?
