rajjes
I am finally getting close to re-stepping the mast after replacing the rigging and have some question on how the shrouds should be attached to the spreader ends on the Proctor Mast of my 1980's Moody. I'm confused as the current setup seems to conflict with the general info found on the web:
1. Should the shroud be securely fixed to the spreader tip or not? - The spreader ends have a screw down clamp to prevent the shroud from jumping out but it does not clamp the wire tightly so with the old rigging it was still free to run.
2. Should the spreader lie perpendicular to the mast or angled slightly upward to bisect the angle? - The spreaders ends have some up/down play and can be angled upwards a few degrees however their bases seem to be made for a perpendicular fit?
Appreciate your help!
Duncan
Duncan
