Shroud lashings
IJL
23 Sep 2011
Chesterfield
The shrouds on my boat are secured by lashings rather than bottle screws. This is great because bottle screws are very easy to bend when raising the mast. Is there a recomended knot or technique for the lashings? one of the dinghy forums recomends multiple half hitches. Any thoughts?
There are lots of similar lashings in the rig of a square-rigged ship. When I used to work on them occasionally, the rule I was given was that for anything supporting a person there had to be at least four turns, four half-hitches, and four tucks through the lay of the rope. That was deemed sufficient for a footrope or craneline holding several people a hundred feet in the air.
Our old boat (24 feet) used a lashing for the forestay. I used to do six or eight turns and four or five half-hitches. I couldn't do tucks through the rope since it was tight (the ship lashings above were generally fairly slack unless someone was standing on them) but I would weave the end of the lanyard through a couple of the turns of the lashing to help hold it in place.
Katie L has Dyneema lashings
I used two bits of dyneema for each side
one attached to the boat and the other to the shrouds
each with a bowline
they are each taken three turns and then clove hitched off
that way if one rots and falls apart I still have a second
the trouble with using just one bit of rope is that if it gets cut then the mast is free to fall over
the lashings have been on for two years now
numerous mast drops
still looking good
D
As a wooden boatie I'd probably prefer the first of these two suggestions. But I'm sure that either would work okay.
Traditionally, shrouds were fastened with deadeyes for tensioning, and the lanyards used were made off like this --
The key thing here is Fig 3.1, showing three racking seizings, which were considered perfectly adequate.
Mike
Bit of a thread revival but I'm seriously considering getting (at least) my Corribee's lowers made up with a loop so I can ditch the bottlescrews and simply lash.
I like Dylan's redundancy idea.
Would I regret ditching the bottlemscrews?
Is 'lashing' the right term for this? If not what is?
Take a look at free range sailing on YouTube for some real world dyneema rigging usage and ideas on how to set it up
