bumblefish
I recently asked for advice on methods of beefing up my U bolt shroud attachments on my Elizabethan 30. Lots of advice given and quite varied. I also contacted the members of the Elizabethan Owners Association who had/have an E30 to ask how their shrouds were attached. Also a range of replies. So this question is to ask the forum about one particular suggestion. If an angled bracket was installed beneath the U bolt below the deck which was also attached to the topside by 2 or 3 bolts would this lead to strain on the topside in very localised areas in the absence of backing plates, which would need to be on the outside of the topside?
I am currently considering putting new chain plates through the existing toe rail, bit of chopping required, and backing these up with substantial plates inboard. This may reduce the maximum sheeting angle of the genoa but is probably the most robust solution.
