skyflyer
Anyone with any experinece or info on this?
In the shower there is a small switch which when toggled powers the shower waste pump.
The routing of the waste is through the shower pump, then through some sort of plastic 'box' shaped device, then on upwards initially, looping over through an anti siphon loop and then down to the hull outlet via a seacock.
The pump only 'intermittently' picks up water (and when it does so, makes a deeper 'labouring' sound).
I thought, initially, the hull outlet was blocked so closed the seacock and disconnected the hose. Slowly opening the seacock a whisper, confirmed that that was not blocked!
I then put a bowl under the end of the hose and ran the pump again. No problem - water flows at a good rate.
However, when reconnected, the same problem.
Any suggestions and what is the little box shaped (valve?) thingy
Cheers everyone, in anticpation
