Tim O
Hi...when i purchased my Countess 33, I was under the impression from previous owner that the shower simply drained into the bilge and was then pumped out when needed by switching bilge pump on.
Recently noticed shower was not draining away so investigated further and found that in fact it drains via a pipe (about 1") into one of two interconnected holding tanks under the cabin sole....the toilets go into the other one if diverted from going out to sea...
Anyway seems that the tank into which the shower drains is full and the shower is backing up...and furthermore, since I have pumped out the other holding tank, that maybe the interconnecting pipe between the 2 tanks is also blocked as this did not solve the problem. (That needs dealing with too...which means taking the lid off the holding tanks....looking forward to that one!!!)
Anyway, it seems to me a bit daft and unnecessary filling up holding tanks with shower water.....
Simplest solution is to cut the pipe to holding tank and just let the shower drain into the bilge then pump out with bilge pump overboard?
Anyone see a problem with that that I am missing?
Slightly more complex option is to fit a 3 way Y diverter with tap to divert water either to bilge or holding tank......
Full-on solution would obviously be to fit a shower sump with a pump to pump it out via the sink outlet, but this seems an unnecessary waste of time effort and money when Option 1 achieves the same result!
Thoughts??
Thoughts??
