Seadog17
Is there a favourite waterproof socket that can be fitted to the front/rear of the boat so that you can just plug the shore connection in without the wire passing through the hatches?
Many thanks.
Many thanks.
Many thanks.
Think you will find it should be a plug fixed to the boat not a socket
Many thanks.
There does not seem to be on the market any properly waterproof bulkhead plug with cover that takes a standard 16a shoreline socket. Those suggested above are either unprotected, splash resistant only, or take special (i.e. expensive) cables.
Anyone know different?
Wifey pooh has just ordered this one,
http://www.power-store.com/view-item.asp?itemid=1369&id=227&
with plug type socket etc. for my Chrimbo pressie Will save a lot of faffin' around when visiting the boat.![]()
According to the photo of the pins that wouldn't fit my shoreline cable. Have you ordered matching sockets for your power cable too ? Or am I missing something ?
Boo2
OK Ill put my work hat on!
About the best rating that you will get in industrial plugs and sockets is IP67
this is Immersion up to 1 m, however this is normally only when the conector is mated. The exception to this is a Cee Norm 2485 or 2638 that have a cap to go over the pins when not on use
http://www.ceenorm.co.uk/product.php?xProd=9455&jssCart=d4167232ea44d33f801f5f4294bc021e
J
J
