Shelf in fridge
Sam_Steele
22 Apr 2003
Winchfield, Hampshire
I am wanting to put a shelf in a fridge ( opens from top). I want to attach a runner on which the basket can slide along. the fridge is made of stainless steel. What is the best way to attach it - glue ( and if so what glue for for fridge temps) or some other way?
thanks
sam
roger
Overwinter in Sweden, sail in Northern Baltic, liv
You obviously can't weld. Pop rivets or self tapping screws seem dodgy to me - unless you can seal the holes properly. I don't think glues would work.
My preference would be to make up a frame that hangs from the top or sits on the bottom. Made up of small section angle it need not take up much of the fridge.
bugs
14 Jul 2003
Galway
I came across a 3M brand double backed tape some time back. It was incredibly strong, apparently used in aircraft inidustry. Im sure it would work and would be clean and easily applied.
If its a nice smooth surface you could try suction cups with hooks as used in showers and with the buckets for handhelds that attach to cockpit surfaces. Removable for cleaning and readjusting.
pvb
UK East Coast
I'd be tempted to use SS self-tappers. Secure, but can be removed if you need to.
