Sheeting Angles
roboandkate
18 Apr 2005
Falmouth UK
I'm looking for a good book explaining sail sizes, sheeting angles, sail twist etc.
Before I spend a load of money doing some modifications I want to understand enough to hold a sensible conversation with an 'expert'.
Any recommendations?
Richard10002
17 Mar 2006
Manchester
No expert but, if the tell tales at the bottom are flying, and those at the top are stalling, the car needs to go forwards, and vice versa.
presumably, if you want to point higher, (but with less power), the car tracks could be moved inboard, and vice versa.
I'm sure you want something more technical <g>
Lakesailor
15 Feb 2005
Near Here
Steve Goacher, who makes championship winning sails told me that the sheets should point to a spot on the forestay 40% up from the foot to the head.
So you adjust the car until that happens.
I hope I remembered it right.
Marmalade
15 Feb 2005
Essex
High Performance Sailing - I think by Frank Bethwaite - technical sailor's bible - tells you way more than you'd ever need to know
Simon
machurley22
19 Jan 2004
Scotland
Looking at Sails by Bruce Banks & Dick Kenny and/or Sails for cruising Trim to Perfection by Mark Chisnell. The latter is "supported by" Hyde Sails but no less informative for that.
VicS
13 Jul 2002
I cannot recommend a book but you might find some useful basic info Here
PBO have run some good articles in the past. They must just about be ready for a re-run.
charles_reed
29 Jun 2001
If you want the standard
reference book get C A Marchaj's "Sailing Theory & Practice" out of the library - he devotes a whole chapter to sheeting angles and , most importantly, gives the theory and principles behind that. ISBN 0 229 64253 5.
Alternatives are "The Best of Sail Trim", collection of articles from a number of sailing journalists and one or two who actually trim sails for a living. ISBN 0 229 11843 7
Or, on a more chatty note Jeremy Howard-Wiliams "Sails". ISBN 0 229 11824 0.
In fact sheeting angles for foresails are dependent on so many factors rig (masthead/fractional), overlap (solent or % genoa), construction (horizontal or mitre woven/ laminate), but is generally in the area of 60-35 degrees.
Inselaffe
18 Jun 2003
Lisboa
