Roach1948
I was interested reading the article regarding Zeerand's (previously Merlin) restoration in the latest copy of Classic Boat. It seems from the article that she was splinned with epoxy cloth and then sheathed with epoxy. The owner quotes "The most important thing was to choose the right epoxy system, otherwise you end up with rotten wood pulp".
It seems this is a common view on the continent as I have a Swedish friend that runs a wooden boat yard who says if you sheath don't epoxy the interior and let the wood breath to stop the yacht rotting.
I am confused as there seems to be two approaches to sheathing; coating or not coating the interior. I was told by SP systems that if I were to sheath I needed less than 12% moisture content in the wood and that I MUST epoxy coat the interior. I also would need to spline the seems. The reason being that the hull would be a solid construction and any moisture coming in from the inside would make the wood move thus cracking the sheathing on the outside of the yacht.
I wonder which approach is correct?
