silverseal
Yesterday, nearly lost the mast in a Force 5, when a phosphor bronze casting failed- a fin to which the forestay is attached sheared away. Am currently making two mild steel plates to be bolted each side of the undamaged portions of the fin, and am proposing to use 4 off 6 mm stainless bolts to spread the load over an 8 inch length of plate. Anybody any idea of the force required to shear a 6 mm stainless bolt. If this works OK will get stainless plates made over the winter...
