Durgan
New Member
Info required .... I am in the process of purchasing a SHE 31 which needs to be re-engined. Currently has the original Yanmar YSE 8 and I am planning to use the Yanmar 2GM20F. Understand the SHE has a tight tolerance between prop/P bracket/ hull & whilst there is no problem with the fitting of the 2GM20, I am concerned about the space to fit a larger prop ( 13" ? ). The SHE is currently in the water and thefore inspection is limited.
Have obtained the necessary measurement details from a SHE 32 - Would the 31 be the same.
Thanks.
Thanks.
