Sharp Autopilots Ltd, Ramsgate
mcini
15 May 2006
I'm seeking for documentation and the User Manual for a B45
Sharp Autopilot. Anybody knows what happened with this company that manufactured very robust pilots. There is still some service or egineer capable of advice and repairs ? Any info fully appreciated.
trouville
N/A
10 Jun 2004
crusing with an Arpège
I think you may only be the second or third person to ask about sharp.I dident get any replys when i had problems with mine.
I do agree they were well built.mine replaced the autohelm replacement bought in 1986? when in 1988 the new autohelm failed,fixed under garentee failed again in89 when i put it overboard!
My sharp continued to stear untill 1996,it was wonderful i entered ports still useing the compass ring to change course.Much easier than useing my new autohelm 1000 with key pad,(2005)Id still prefer a compass ring to turn rather than chosing 1Degree 10degrees or tack!
arndor1
11 Aug 2007
Malta
I have a Sharp autopilot on my Hurley Ketch...manufactured in '71...it works very well to this day, but I have a small problem regarding replacement belts for it...and after 10 years of ownership I am still discovering new settings!! anyone know where I can get a manual?
ffiill
5 Sep 2007
I have Sharps manual-can scan it for you-may take a couple of weeks until next at boat-
contact me phil@tasteofsailing.co.uk
Its great because as well as fitting and using instructions it has full schematics of circuitry and testing schedules.
MAKE SURE YOUR RELAYS (which control switching of-hydraulic pump motor or electric drive motor)have clean contacts-they can stick on due to build up of deposits caused by sparks and boat will take either a sharp right or left!-its taken me 2 yrs. to solve this problem.
RS Components stock these Octal Relays but you can clean them similar to traditional contacts in car ignition circuit.
I always remind myself that these units represent highest evolution of Solid state electronics before the chip took over!
as for belts try Wyko/Fenner-usually have depots in most towns or
www.hpcgears.com
They do pulleys belts gears shafting etc.
Phil
DouglasW
18 Sep 2022
www.hpcgears.com
Phil
Phil,
Following your comments on YBC.com
A copy of the User Manual for the Auto pilot would be much appreciated when you have time.
All best wishes,
Richard White
01799 543239
Aja
6 Nov 2001
Phil,
All best wishes,
Richard White
01799 543239
richard@quendonent.co.uk
You might be better emailing Phil directly at the email address above.
He posted this in 2007 and last seen on this forum back in May 2024.
Good luck!
