Bosun Higgs
N/A
My set up is a 25mm drive shaft to a Radice folder via a shaft log with a water lubricated bearing and a Volvo seal at the other end. Now the bearing has some slop after just 18 months and before my accident reported elsewhere, the Volvo shaft seal had started to drip after the same length of time. Both these events seem quicker than they should be, so what is wrong?
The shaft itself has wear that you can feel with finger tips, but the most I can detect with a micrometer is 0.08mm or 3 thou. The surface is smooth and shiny.
Any ideas? Any engineers out there who can comment on wear limits? Personally I wonder about the bangs and bumps from the prop.
