gtmoore
I've had a good look through all the engine vibration posts made here but I would like to run my problem by you all just to see if any of the myriad things it could be is more likely (sorry it's a bit long).
My Moody 29 was re-engined by the previous owner a few years ago with a 3 cylinder Beta 20hp which is super smooth and barely moves on it's mounts at any revs. I bought the boat last year and before I used it in anger my yard advised me to have larger engine bearers fitted (now 3"x2" steel boxes not 2"x2") which I did and obviously had the engine aligned. I also have the Volvo seal that doesn't need a greaser and certainly doesn't drip at all which is great.
My problem is that after about 1700 revs I get a sort of clatter that slowly comes and goes in about 3 second intervals. At higher revs the noise stays the same but the intervals get shorter. It truly sounds as if something is loose in a locker and is rattling but believe me I've emptied them twice but the noise remains. It's more of an annoyance as it's not extremely loud. My boat has a long stern tube built in i.e. no P bracket. It sounds as if the shaft may be knocking in the tube but oddly this doesn't seem to be audiable when tied to the mooring (maybe noise from the pop wash is hiding it).
Two more things, a previous post said to check that the shaft isn't bent by seeing if it moves the seal when in gear. It does move a little at idle but when increased it doesn't. Also, I'm not sure if this is related but after a trip round from Dover to Southampton we needed to remove a mass of fishing net around the prop.
Any ideas if this sounds more like alignment, bent shaft, prop problem etc...? I'm a bit worried this could be wearing something out?
<hr width=100% size=1>Gavin
