ean_p
I'm just at the point of buying an Ambassador rope cutter when a small point comes to mind......as the boat has no fixed thrust brg ie Aquadrive or similar then the thrust is taken on the engine mounts ....which been flexible give to some extent...so the prop shaft moves to a certain extent when in either ahead or astern.....looking at marks on the shaft near the gland it would seem to be about 8 to 10mm overall.....how does this relate to the rope cutter blades and clearence therein ???.....am I missing the point here?...is this amount of axial movement so very different to the norm?......or what?
Ian P.
Ian P.
