Con_Brio
During the 2003 season, the shaft anode on my boat twice came loose. The first time, I hauled out (pleasant surprise - relatively cheaply) in Camaret and replaced the anode, new that season, which showed some but not excessive erosion, tightening the new one on the one-inch shaft as hard as ever I could. I also smeared the threads of the bolts with Araldite before assembly though, to be fair, the glue had little time to harden before she was lowered back in. But before the boat came out for the end of the season, I could again hear the same old flapping noise when the auxiliary was put into gear and sure enough, on hauling out, the anode proved to be hopelessly loose again. Presumably with the loss of firm contact, prop, shaft, etc lost their protection.
This hasn't happened before, not even in the 2001 season when I logged over 4000 miles.
Any one got any advice to prevent the same thing happening in 2004?
One suggestion I have been given is to get an anode with stainless steel inserts in way of the bolts, so that erosion of the zinc around them won't cause the anode to come loose - Duff's were said to make such anodes. Does that sound like good advice?
