gasdave
Today I removed my worn shaft anode and purchased a replacement (MG Duff) from my local chandler. I measured the shaft (25mm), checked the internal diameter of my old anode (25mm) and bought a nice shiney 25mm MGD anode.
When I tried to fit my new anode I discovered that there was no way this would fit tightly around my shaft
. Once tightened as much as possible there was a gap of at least 3mm between the two halves of the anode. I wasn't happy with this as it also meant not much screw thread had passed through the nut. The old one fitted perfectly but I can't tell what make it is!
So I had a look at someone else's - similar fit.
Is this normal? Should the anode not fully encircle the shaft? Do I need to visit my chandler again with my receipt?
