Shaft Anode Advice please
dralex
9 Jun 2004
South Devon
I am curious as the shaft drive on my boat has never had an anode on it since I bought it and there is now some electrolytic activity on the p bracket. Should I just fit an anode anyway and will it do any harm if there was never one there in the first place? I'm afraid I'm not very clued up on anodes.
thanks in advance.
Alex
gianenrico
12 Dec 2003
Northern Tyrrenian sea
An anode will eventually dissolve itself (like the Chesire cat) so if in doubt, You should not risk but the cost of the anode (if it disolves it means it was needed and you loose the worth of it, if it does not it means it was not needed and You keep the worth of the zinc.
Cheers,
Gianenrico
P.S.: I would not esitate in mounting the anode of appropriate size on the shaft
andy_wilson
S. Yorkshire / Devon
Shaft Anode Advice
A shaft anode protects the the shaft, or more likely the propellor attached electrically to it.
P-Brackets are usually covered by a hull anode bolted on nearby, and connected electrically from the inside.
Your shaft will run in a shaft bearing that insulates it from the bracket, making a shaft anode useless for that purpose.
dralex
9 Jun 2004
South Devon
Re: Shaft Anode Advice
Thanks Andy- can you explain the hull anode in a bit more depth please and how would I go about fitting one if there is not one already there?
tome
28 Mar 2002
kprick
www.google.co.uk
Alex
The shaft anode protects the shaft and propeller. On my Maxprop, there is an additional anode on the prop.
You need to get the right size by measuring your shaft diameter, then fit it close (about an inch gap) to the P braket to minimise vibration. Before fitting any anode, use a bit of emery to clean the surface to which you'll attach it so there's a really good electrical contact, and then do it up TIGHT.
Cheers
Tom
KREW2
20 Jan 2005
Dorset
Hi
The marine engineer who looks after my boat told me not to fit an anode on the shaft too close to the P bracket, he maintains it can restrict water flow through the cutlass bearing giving increased wear
KW
KREW2
20 Jan 2005
Dorset
Hi
I presume you wish to fit a pear shaped anode something I have just done with the guidance of my regular marine engineer. it is best located within 18" of what it is to protect, and you will need to get to the attachment bolts from the inside. When you have drilled the holes the bolts are secured and made water tight (I used Sikaflex). The protruding bolts on the inside then have to be earthed to the to the engine, if you can get it use tinned wire if not 2.5ml electric cable will do. Then go to outside bolts you are going to attach the anode to and use a multi meter to check the resistance between the outside bolts and your shaft. If you have done it right you will get a zero reading, once this is achieved fit the anode with the rubber backing pad, If I can do it anybody can good luck
KW
tcm
11 Jan 2002
Caribbean at the moment
fit a galvanic isolator to reduce the eleectyrlytic effects of a wehole pontton being on the same earth circuit. Failrine do these for bigger boats, praps not yours. I used Steve of Sure Power to do this, may be able to find a number. £100 for GI, £100 fitting. When drying out, drill thru p-brackket and fit disk-type anodes that present small resistance, and mastic over the nuts to eliminate erosion onnem.
tome
28 Mar 2002
kprick
www.google.co.uk
Just checked the clearance between shaft anode and P bracket from a photo. Confirm it's about 1 inch, and was fitted by my marine engineer. No problems with cutlass bearing.
tome
28 Mar 2002
kprick
www.google.co.uk
Maybe KW. I can see his point but an inch seems ok for clearance. On a high speed craft you'd maybe want more, but I'm only guessing.
Cheers
Tom
KREW2
20 Jan 2005
Dorset
Hi Tom
I'm a bit like you, smile, nod in agreement, then pay the bill
Regards Keith
