sailingjupiter
Active Member
On my MG Spring 25 the shaft as it exits the boat under the hull is closer to one side of the stern tube than the other. Or in other words the shaft isn't central in the tube. I have had the boat 5 years and never bothered with it. But thinking about it there has always been a clatter in neutral (Yanmar 1GM10). I assume it is the shaft rattling around in the tube and hitting the side where it is closest.
If when the boat is out of the water you manually turn the shaft whilst in neutral and engine off the shaft definately gets harder to rotate at the same point for every revolution.
I assume the engine was originally professionally aligned as I have a fist full of invoices for engine work from the previous owner. Would the engine have come out of line slightly over the last 5-7 years?
I'm tempted to slacken the engine mounts and move the whole lot slightly so the shaft exits centrally. But will this be correct? Afterall, alignment remains the same although this may put strain on the cutlass in the P bracket as it may be aligned to that presently. Currently the cutlass doesn't appear to have to much play so maybe the engine to P bracket alignment is correct and the tube is very slightly off centre.
What would you suggest do....anything (as its always been OK bar the rattle in neutral) or take action? If so what?
