johnjfrake
I would like to bolt the plywood floor of my Folksong 25 down securely and thought that a good way to do this would be to set some bigHead GRP bolts into the keel floor and use a sort of T section nut (again with a wide area head) to grip the floor in place! Does anyone have any experience of this technique or any comments on the idea. Note the bigHeads will be set into the grp above the keel centre, not where a fault would cause leaks. Don't want any bit protuberences above the floor for obvious reasons.
Regards
John
Regards
John
