sheyes
I am servicing the Jabsco raw water pump on my Beta engine. There are two seals on the shaft which are there to keep water and oil separate while the pump does its job. Both seals are the same. They are like (black) polo mints which are almost flat on one side and the other side has a deep slit in it which goes right the way round.
I had been told that the slit side should point toward the liquid it is protecting the bearing from which should mean that the seal nearest the impellor should have its slit side pointing out toward the impellor. When I stripped the pump down I found that the seals were put on in the opposite way than expected.
The question is which way round on the shaft should the seals go (or doesn’t it matter)?
Steve
Steve
