Full service £ 450 per engine
Legs year 1 £350 including anoids on Trim tabs
Legs Years 2 £ 500 includiing Bellows replacement
Antifoul £ 450-£550 subject to preping
If you indicate engine type, and where you are based, some of the members can advise more accurate, and rcommend people to us and stay clear off.
Do it yourself and save a fortune.
Unless you are messing with injectors the engine service is really nothing more than an oil and filter change with a check of the belts and replace if neccesary. Shocking what you can get charged for that /forums/images/graemlins/shocked.gif
If it is year 1 on the legs then anode change and oil change well within DIY capability (make sure you have a new seal kit for the plugs on the legs). If it is bellows replacement then I would pay someone who knows how - not worth the risk of messing up (although I do think it can't be that hard).
Anti-foul is definatley a DIY job - use Cruiser Uno at around £65-£70 per tin (one should do) and all that is needed is some masking tape and a small roller & tray
KAD 43s Service £447 each
Outdrives £183 each.
Last year I got the yard to antifoul it and I think it was about £400.
Did the AF myself this year paint was £70 for 2.5 litres. The guide said I needed 5.75 litres so I duly bought 2 x 2.5 and 1 x 750ml.
I wasn't until I opened the 750ml tin I noticed it was 31 quid! I wish I'd bought 3 x 2.5 litre and I'd have used it up on an extra coat.
