Modulation
My shaft seal has done 20+ years with minimal maintenance and problems. This year, however it't started to leak and it needs to be replaced. To do this I need to uncouple the shaft from the flange which attaches it to the gear box so that I can draw the shaft back a bit thus facilitating removal of the old seal and fitting of the new one. The trouble is that the flange which attaches the prop shaft to the gear box looks pretty corroded - at least around the bolt and bolt heads. AND the flange isn't in 2 parts which bolt together. It's a single unit with a cut into its diameter - that, presumably, to facilitate the original assembly when the shaft was inserted into it prior to tightening up the bolts and closing the cut over the shaft.
I've done a search on the forum to see how to approach this but most replies seem very pessimistic with the only reliable solution being to cut the flange up with an angle grinder and replacing it completely. Clearly to be avoided if possible so any other ideas/ experiences welcome.
Would a penetrating oil offer any serious help?
Thanks all.
Photos attached
Thanks all.
Photos attached
