MoodySabre
Mine's being taken out soon to be replaced.
It starts really well, runs well, smokes a little bit, drips a bit of oil and water from the fresh water pump. Starter motor recently rebuilt. The problem I have had is low oil pressure - oil changed, sender changed. Not solved.
The questions is this - is it worth spending money to have the engineers take the sump off, take of the oil pump and investigate the suspected pressure valve (weak/broken spring)? I'm not doing this myself. Or should I try to sell it with this unresolved issue or break it - which I would do myself.
