thanks did you remove and re fit the end piece to attach the barton eye. ahhg i get it you removed and re fitted with screws instead of rivets.I had similar and replaced it with something like this:
Barton Fixed Pad Eye
Slid into the channel on the underside of the extrusion and fitted with bolts and a backing plate, it has held up ok for years.
Instead of replacing the casting with rivets I tapped it for screws which has proved handy. According to Selden that cast loop should not be used for attaching the mainsheet, what it is for I am not sure.
Once you've welded and redrilled, try using a soft shackle there instead of metal on metal - then it won't wear through again.
I don't know in which direction the force will act on the slider, but if it's forward, I wouldn't rely on that screw. Maybe a 2nd soft shackle back to the worn eye or a strong stopper screw up into the boom to stop any forward movement.the other spare . ive slid it all the way to the end and looks strong enough.
I think i will be ok as just been the boat and noticed two sliders one is for the kicking strap and the other spare . ive slid it all the way to the end and looks strong enough.
Those security alan keys are available in the UK. Draper used to do a set for various types of 'security' bolts/screws.As previously mentioned, Post # 6, - it is common place now for the main sheet to be attached to a tape loop/band that is round the complete boom. The tapes are commonly 25/35mm wide - which spreads the mainsheet load. You could make the loop yourself using off the shelf nylon tape and sew it together, by hand, using dyneema braided fishing line.
We have a newer Selden boom. The end casting (at both ends) is secured with fancy Alan key bolts which for some reason are security bolts. They have a recessed hexagonal slot in the head with a little pin in the centre negating their ability to use a conventional Alan key. Our outhaul failed, in the middle of nowhere - and we had not been supplied with the appropriate key. I was not impressed. . We bodged and took the boom apart (the outhaul is quite a critical component
) and replaced the outhaul - but check your boom and the method of assembly. On the underside of our boom is a slot, the length of the boom. The slot is equiped with slider 'eyes' for the reefing lines - sort of like pad eyes - pretty chunky., cast stainless They are are located and secured with those same security Alan bolts.
I note the comment that Selden say the offending hole is not to be used to attach the mainsheet - which makes me wonder why it is there at all - as it seems the obvious place to attach a main sheet. If its not to be used for the mainsheet - why have it there (to be misused) ? The end casting on our newer boom has a 'thing' like a handle or hand hold - the use of which - no idea. We have had tape for the mainsheet from the outset.
Jonathan
Definitely right there. I have had a track and traveller car wear out from rolling on mooring. Now I disconnect topping lift and drop the boom on to the cabin top. No movement although some helpfulls on occasions have told me my boom has fallen down. ol'willDid the wear come from sailing, age or wear while moored? I secure my booms (and anchor) to stop any movement when moored and stop wear on boom end and gooseneck fittings. On a previous boat kept on a swinging mooring I had significant boom wear from rolling.
