Second hand Aries windvane
David Payne
New Member
21 Nov 2009
Worcestershire
I have been offered a secondhand Aries windvane. Have you ever fitted one? Are the fitting instructions available?
I have no real knowledge of the original yacht other than it was home built and in a small b&w print from the 1970's it looked a bit like a SCOD.
Obviously the brackets and mountings would need to suit the transom etc and the control lines and blocks would need to suit the tiller geometry, but are these windvanes otherwise standard, or is it necessary to tailor (or order purpose made) parts to suit the yacht geometry?
Thanks in advance for any help.
David
min came with some unusual brackets but a bit of lateral thinking solved the problem
just see what comes with the gear & go from there
Leading the lines is quite easy & I do not have fixed blocks but rope mounted ones so i can remove quickly
