vas
evening all,
quiet working and busy setting up the features of a new arduino based black box for each engine that will do the following:
and a few temps...
Now then, I've already bought a dozen DS18B20 temp senders following recommendations in PBO, already used one on the fins, got to find what to do with the others before starting stuffing them in fridges
These are 6mm dia and approx 30mm long ss sensor leading to a 2m long cable.
So for each engine I'm planning for:
Bear with me.
If I fit one on the endcap of the charge air cooler (that's the first one where the seawater goes after the strainer and pump and where you fish bits of vanes...)
and I fit another one at the endcap of the coolant heat exchanger (that's the last one before the mixer). Through my Ivecos seawater goes cac, g/b oil, oil, coolant, mixer
Then cant I get the delta Temp and when it's more than something get an alarm ringing?
Also by monitoring these temps I can see if there's something abnormal in the cooling circuit.
Does the panel agree or am I missing something?
Now if we agree, I have a problem to solve!
these cylindrical senders are a bitch to get them in half-decent contact to something else. I guess they expect them to be freestanding on air or dipped in a reasonable liquid.
So was thinking of spotting some blanking nuts (I've seen them around in the heat exchangers) and get my machinist to redo them in bronze much thicker and drill a hole (that doesn't go all the way through obviously!) in order to fit with a bit of heat transfer compound that we use for el. chips heatsinks.
Makes sense?
I'll spot the ones tomorrow onboard, undo them and measure, should be fairly straight forward.
any ideas on that?
For the record, all that data will go to a Maretron DSM250 display on the f/b kindly donated by JFM, once more many thanks John!
Unfortunately as I've mentioned before although I really love my Garmins, they wont be able to present ANY of that data as they are only supporting the part of the NMEA2000 protocol that they do have sensors for, which is a bit poor imho and even g/b oil pressure which they do support have a v.low limit that wont cut it.
cheers
V.
- gearbox oil pressure (got the VDO sender ok, but no gauge on lower helm nor space to add another two 52mm VDO gauges...)
- gear selector in order to park fins when reversing (ordered 2 uber cheap chinese rudder sensors to mount next/behind to the g/b selector lever)
- EGT (have the K-type thermocouples and tiny boards, tested working)
and a few temps...
- g/b oil temp
- two of these babies to check the seawater temp though the cooling circuit.
Bear with me.
Makes sense?
any ideas on that?
cheers
V.
