MountainGoat
Hi all. Long time lurker, first time poster, but am hoping for some advice.
We have a Sun Odyssey 30i, which we bought last year after the previous owner barely sailed her, so she's basically a brand new second hand boat. I was lucky to get her.
She came with an ST60+ tridata, ST60+ wind and ST6002 autopilot head on the binnacle. These are linked via Seatalk to an SPX5 autopilot, which is linked via Seatalk to a C90W plotter above the chart table. This was linked to a Ray 55E radio via NMEA0183. The ST60+ instruments directly interface to the speed, depth and wind transducers.
The radio wasn't receiving properly and determining it was basically unserviceable we recently replaced it with an ICOM 506 with built in AIS receiver.
In order to get AIS on the C90W, we purchased a SeatalkNG starter kit and the NMEA2000 adaptor cable for the radio. Unfortunately the radio doesn't get GPS data from the chart plotter over the SeatalkNG for some reason, so we also connected the radio via NMEA0183, and it all started working.
We now have plans to upgrade the instrumentation to something more modern. In particular, the chart plotter is no-longer supported and despite running the most recent software update from Raymarine, its AIS support is best described as problematic.
I'm looking at an A9 series MFD to replace the C90W, and also looking at an i70 for the spare spot on the binnacle which will give me, amongst other things, AIS at the helm.
Sadly the A9 series won't be a drop in replacement for the C90W because while the C90W supports Seatalk1 and SeatalkNG, there is no Seatalk1 interface on the A9.
If money were no object, the thing to do would be to replace the two ST60+ instruments with an i40 and an i50, and the ST6002 with a p70, connect the SPX5 with Seatlak NG and thus eliminate Seatalk1 from the boat completely. However, that is an obscene amount of money to spend to replace perfercly serviceable instruments with ones that do exactly the same thing, but are black instead of grey.
So I figure we'll keep the two ST60+s and the ST6002, and try and bring them into the SeatalkNG/NMEA2000 world.
So my questions are as follows:
1) Why isn't the ICOM 506 getting GPS data from the C90W over NMEA2000? It sees the C90W and is selected to use it, but doesn't get a position. Note that the C90W is getting AIS data from the radio, so the SeatalkNG network is working.
2) If, as I'm assuming, this is down to the C90W not being properly NMEA2000 compliant, will the radio be able to get GPS data from an A9x without having to resort to connecting them via NMEA0183?
3) The C90W is currently bringing between the Seatalk and SeatalkNG networks. The A9 series has no Seatalk1 support, so I'll need another bridge. The obvious option is to use the Seatalk1 to SeatalkNG convertor kit and have the ST6002, two ST60+s and the SPX5 connected to each other via Seatalk1, then connect the SPX5 to the convertor and somehow bodge the Seatalk power (since the SPX5 and the STNG/ST convertor will both be wanting to power the Seatalk bus).
However, given the SPX5 has NMEA0183 out, and the A9 series has NMEA0183 in, can I use the SPX5 as a Seatalk1 to NMEA0183 bridge and get the transducer data to the A9 via NMEA0183?
4) If I do bring the data into the A9 via NMEA0183, will the A9 bridge the data onto the SeatalkNG bus and, given the A9 will be connected to the SPX5 via SeatalkNG as well, will this create a network loop, and if not, will the A9 still talk to the ST6002 properly?
Given the likelihood of something going wrong between the A9, the SPX5 and the ST6002 if I bridge via NMEA0183, I'm wary of going down this route, but if it will work it will save me a bit of money and make power distribution easier than using a Seatalk to SeatalkNG convertor.
I realise there's a lot there, and I hope what I want to do is clear enough. I'd be grateful for any help.
Sarah
Sarah
