seatalk junction box nessesary ?
gniersma
New Member
3 Jan 2005
I ve to connect several seatalk instruments together.
I understoód that seatalk is a bus system. Unfortunatly my radar, vhf, remote control have only one seatalk connector. the ST60 intruments have two. So how can i connect everything together?
I understood that raymarine sells junctionboxes. are these boxes active devices or is it possible to connect the wires in parallel ?
I had the same problem, and after having asked Raymarine (who advocated the use of the junction box), I just connected the wires together and all works well (same-colored wires go together).
The junction box is passive, no fancy electronics inside!
If you are adding to an existing arrangement I suggest you check for continuity of each conductor rather than just rely on colour I found some wrong polarities in my system.
The ST60 wind/tri-data instruments take their 12 volt power from the Seatalk bus. So whichever other instrument powers them(Raymarine suggest tiller pilot/Autohelm which is fused to 12 amp ) just make sure there is a 5amp fuse in the line to protect them in the event of an overload
"The ST60 wind/tri-data instruments take their 12 volt power from the Seatalk bus. So whichever other instrument powers them(Raymarine suggest tiller pilot/Autohelm which is fused to 12 amp ) just make sure there is a 5amp fuse in the line to protect them in the event of an overload "
Seatalk has three wires, data, power and common. Is there any reason why you can't supply separate power to instruments and just connect up the databus and common?
Ian
" Seatalk has three wires, data, power and common. Is there any reason why you can't supply separate power to instruments and just
connect up the databus and common? "
This worked for me, and allows different instruments to be fed via separate circuit breakers.
See http://tinyurl.com/8ox8v "Can I cut the red wire to the SeaTalk instruments?" and the answer suggests not.
But http://tinyurl.com/adyvg seems to differ.!
