Narcosis
New Member
Hi! I'm considering purchasing a motor cruiser between 24-26' and viewed a Searay 250 Sundancer today. The boat is 1996 with the 5.7 Mercruiser EFi / Bravo 3. 300 hrs. The hull appears in good enough shape, with the usual dings and scratches I would expect for the age. Water was connected and the engine appears in good shape too. A couple of things concern me: 1) the carpet in the cabin was wet and was generally damp inside. The seller said this was a build up of condensation dripping down from the ceiling hatch. I doubt that. What could be the cause? 2) The instrument panel is badly weathered and the gauges are virtually impossible to read due to condensation on the inside of the glass. Big cost to replace?
Should I spend the money on a survey or just walk away?
I've looked at another Sundancer with 5.7 carb engine with Bravo 2. It's got 600 hrs but in better overall condition and not wet inside!
Also is there much difference in reliability / efficiency between the carb and EFi Mercruiser 5.7 engines?
Confusion reigns!
Confusion reigns!
