SEALING WINDOWS
mhouse
27 Jan 2002
Here
Ive just had to seal one of mine in a hurry and have found that Wicks sell a silicon sealer for heating systems that sets under water , and it sets clear.
Just the thing to keep in the tool kit.
davidbains
15 Nov 2002
There's a huge range of bathroom and window sealants in B@Q.
I suspect they're good enough for marine windows, but should not
be put into Norseman or Stalock terminals.
pete
Here
Contact Hunter and they will supply you with the correct gasket at a very reasonable price as a mate of mine has just done on his Horizon 23.
snowleopard
Oxford
tell me more
i desperately need to replace the useless sikaflex seals on my windows, where can i get the right type of neoprene?
heard it worked perfectly on a aussie boat we met in europe last year which seems a good test to me.
ordinary building grade silocon works very well i used it on by boat a few years ago and ive had no problems. its suppost to have a life of 15 years + it only costs £2- £3 a tube avalible from building mercants (their the cheapest place to buy it from) or b&Q if you whant to get robbed blind.
if its a rubber seal u need to make you can buy sheet neopreen in various thickeness from 1mm upwards from companies specilising in seals and rubber try the yellow pages.
