StevenJMorgan
I'm in the process of replacing some underwater through hulls - first time I've done this and for obvious reasons I want to make sure I get it right.
Is it the usual trick of banging on loads of suitable grade sealer, crank the fitting up finger tight, wait until the sealer has gone off then torque up?? Trouble I can see with this method is that you will have to try and avoid the 'male' part of the through hull from turning at all whilst cranking up the nut for fear of breaking the seal.
Alternative I guess is to bang on the sealent and tighten up and be done with it. What method does everyone else use??
