Mister E
I have read a lot of stuff about sealing the through Hull but have not found any information about sealing the threads.
Do you just do them up really tight?
Tru DesignI have read a lot of stuff about sealing the through Hull but have not found any information about sealing the threads.
Just bought some 55 after the PTFE failed to seal a joint on my cold water system. Doing the job tomorrow, any tips? Does look pretty straight forward TBH.Did two Trudesign valves with Loctite 55 sealing cord seven years ago. They are still fine.
Where did you find the back nuts?I used ptfe tape and a back nut so that i could align the handle.
Originally from tek tanks. But having just looked they dont list them.Where did you find the back nuts?
No tips, apart of checking a few YouTube videos out. It is not about feeding the thread into the thread channels. But to build up the thread around the fitting. You should have sufficient wire thread on to need some force to spinning the valve on, while still able to adjust the position with some effort.Just bought some 55 after the PTFE failed to seal a joint on my cold water system. Doing the job tomorrow, any tips? Does look pretty straight forward TBH.
Worked perfectlyNo tips, apart of checking a few YouTube videos out. It is not about feeding the thread into the thread channels. But to build up the thread around the fitting. You should have sufficient wire thread on to need some force to spinning the valve on, while still able to adjust the position with some effort.
