laika
I recently fixed some blisters in my rudder by grinding out, leaving to dry, then filling with epoxy and csm. Lots of advice, some differing substantially, kind help from people here, but mostly I followed the advice of the yard boatwrights, only replacing their emulsion bound csm with some powder bound which I bought After sanding the guys here advised me to cover the imperfections with International Interfill 830 (which I've done). Problem is I've got 3 conflictin recommendations for the next step:
Boatwright #1: Coat of Gelshield, coat of underwater primer
Boatwright #2: 3 coats of Gelshield (then AF directly on top)
Chandler: *don't* use gelshield because it's solvent based (despite being 2 part) and whilst fine for use on pristine gelcoat, may get in to imperfections in repaired surface and cause serious problems. Instead use 2 coats of a non-solvent based epoxy like hempel sfe 200 followed by underwater primer
I'm inclined to believe the Chandlery guy who always seems particularly knowledgeable and gives me reasons for things. The boatwrights just say "Use product X because it's what we use" and I wonder if I'm trying their patience with questions but they're too nice to just say "go away". I also wonder if pro products sometimes have the same name as DIY products but a different composition, leading to the conflicting advice.
I don't know what the opaque material the non-filled bits of the rudder are (Would it be gelcoat without white colour?). I *presume* the reason for this first coat(s) is to seal parts which aren't already epoxy. I presume that the primer is because it sticks to AF and expoxy bethan antifoul stick to epoxy. But how to resolve the conflicting advice?
Siimilar confusion exists with what to do with the edges of the iron keel where I've ground away rust and applied rust converter:
Boatwright #1: Interfill 830, gelshield, primer
Boatwright #2: epoxy filler (unspecified), gelshield
Friend: Tar, primer
Chandler: Underwater primer only: The rust will come back forcing the epoxy coat from the keel causing lumps: better just to prime and expect more rust flakes
Of course I expect differences of opinion here, but good reasoning can convince me
Friend: Tar, primer
