dragoon
Hi,
recently I've had a coolant leak on one of my engines (Volvo TAMD 40s). I tracked it down to a leaking pipe that goes between the block and head at the very back of the engine.
This pipe is flanged at one end (sealing with a gasket and bolts), and seals at the other with an o-ring (parallel push fit joint).
The end that was leaking has the o-ring. I removed the pipe, cleaned everything up, sourced a new o-ring and refitted (with a little instant gasket).
I then refilled the cooling system (which takes an expensive amount of anti-freeze) only to discover to my horror it still leaks - though not quite as bad as before!
I plan to drain the engine again (pumping the coolant away so I can reuse it).
Does anyone have any thoughts on establishing a good seal? Any recommended product? The surfaces of the pipe and the hole in the block were quite good, but the fit is fairly loose.
Cheers,
Paul
Cheers,
Paul
