sealine s25 LEAK! LEAK! LEAK!
sundancer9000
11 Nov 2007
Northern Ireland lough neagh
was checking boats bits n bobs before putting back into water. When i checked the water system the water pump ran continuously! also i could hear water running in behind the toilet sink unit then to my horror the carpet outside the shower unit became wet!!!! how do i get access to the sink unit in toilet? and has anyone else had similar problems? looking forward to an easy solution! many thanks .
The plumbing should all be pushfit Hep2O so it's must likely a loose connector rather than a burst pipe. You should be able to get access to the tap connections from somewhere under the sink, without having to remove anything structural.
I'm not familiar with the S25, but under the sink on ours there's a cupboard and at the back of that is an opening that (just) lets you get a hand in to teh pipework...
If anything like the older s240 then you will need to remove the "bowl" which will be siliconed in (if it's not an integral moulding), an alternative was to remove one of the aft berth access panels to get your hand through.
I dont think they put an undersink cupboard in the s25 so they must have plumbed this before assembly, might pay to speak with sealine to find an answer to the access arangements.
PS, Watch out for unfinished edges when putting your hand through, fibreglass is razor sharp & the red stuff is hard to remove from the upholstery!
