PRH
Anyone out there have any idea what might be on the constant live "Aux" breaker as mine is tripping or is it a case of a previous owner has wired something to it that I will have to find!
It's usually the bilge pumps and the radio memory supply.
Leave it tripped (while you are inboard of course!) and see what doesn't work? Simple I know in theory
From memory i think there is 3 Aux switch/breakers, I think with mine i can account for 3 as follows. one is the aft shower/sink sump pump and the other is for the forward heads sump pump. I only discovered this when after taking a shower at either the aft or the front heads the water that drained from the shower entered the bilge in this area and had to figure how to supply power to the pumps. 3rd Aux switch i think is wired to the tv aerial amplfier.
My thoughts were simply that if it appears that all works with it tripped (including bilge pumps!) then leave it off completely until you do find it. One thought is that something was attached in the past to it and perhaps snipped off when owners changed and tree may be. Loose live cable dangling somewhere that trips when it hits something (acting as an earth). Just another aimless thought!
maybe you should move the wiring for the actual shower circuit off the Aux to the shower circuit switch save you having to stick a label on the Aux.Just in case anyone else searches the forum for this, the answer on mine is that it supplies the shower sump pump. Strange as there is already a breaker marked "Shower" which obviously does nothing!
i keep meaning to label mine as i always forget which Aux is which
