Sealine 330 (F33) "Patio" Door Problem.
Teddy
12 Aug 2001
Thames non tidal
Sealine 330 (F33) \"Patio\" Door Problem.
Has anyone had a problem with the bottom runner of the curved sliding door fitted to these models? Mine has started started to grind metal to metal on the right hand lower edge.
Each end (lower) has 2 rubber plugs, behind which are screws. Are these for adjustment, or will they release something if turned? I am reluctant to fiddle without asking, just in case. At least it works at the moment.
Perhaps someone knows who the manufacturer might be for possible spares.
Re: Sealine 330 (F33) \"Patio\" Door Problem.
Under the ruber plugs the screws act as jacks and can lift the door up or lower it. You might find by raising the door up might improve things.
BUT count the number of turns in case it gets worse. Also adjust the door slightly open so you can make sure it stays upright to the frame. Check it locks after!
For those with similar doors from Trend Marine, just received the following:-
"It sounds as if your door has gone out of adjustment, on each bottom corner there should be a hole that should give you access to an adjustable wheel. It would be worth trying to adjust this with a Philips screwdriver. If this is not successful then the wheel could have collapsed which if it has you should be able to purchase one by contacting our sales department. If you need any more info then please do not hesitate to contact me."
While were on the subject of Trend, a big 'bouquet'for great service when I contacted them for spares for both one window and again for replacement door runners.
Very knowledgeable and prompt parts despatch.
Ask for Tina....she's the biz.
