robdorling
New Member
Hi guys
Im Rob and im new here and a novice marine engineer (very novice)
My port engine was running a little hot (over 80) so i checked a few things and found a cracked but intact impeller so i changed it and run out for approx 2 hours and all was fine , I moored for a couple of hours and 10 minutes along it reached 90 degrees so i shut it down and checked and the pump housing and stariner pot was very hot , upon inspection it appeared that the flow to the pump was restricted so i filled the system with water and run it up and has been fine since and running dead on 80 degress !! i am going to change the impleller again as ive beenm told any lack of water and heat can damage them !! , My starboard engine on the other hand appears to run cool around 60 degrees , Is this normal ??
