Graham_Wright
I fitted a deck gland sealed with silicone sealant. Needing to remove it a few days later (poor planning) I discovered the sealant was only cured near the perimeter. I assume it needs air to cure. Is this right? It would explain why the cartridge nozzle is only blocked a short distance from the end.
Will it eventually cure or is there an alternative sealant (possibly two part?) that will self cure?
Then I guess it would be solid in the cartridge from the day of manufacture.
Apologies for the naïvety.
