Frank mellin
Purchased a 40 plus engine and decided to replace carb jet to allow 25/1 fuel mix.
Put back together, but after using priming button fuel poured out from the overflow hole in side of bowl.
Is this correct
Ie does holding priming button hold flow open until released and should fuel escape from side of bowl if flooded.
Engine started first pull but revs continued to increase despite throttle lever being closed.
Could only stop by turning off tank tap and waiting for fuel to be exhausted.
Am sure there is a simple explanation only clouded by my stupidity.
Any advice appreciated.
Is this correct
