Seacocks
Depends on how far above and what they are for. I neglected to take a bilge pump outlet far enough above the waterline and dried out one night on that side. syphoned water back into the bilge. Fitted a one way valve and then later a seacock . Have seacock on my current sink and wash basin, both above the waterline.
Do not have them on the cockpit drains, but I do on the shower outlet, which is 400mm above the waterline in the transom.
I cannot recall where the electric bilge pump exits :unsure: . I have never had enough water in the bilge to submerge the electric pump. This thread has reminded me to check. I have checked the switch in it whenever I have raised the cabin floor, as a matter of course.
The hand pump does have a valve to the outlet in the transom which is circa 400mm above WL .
I would add that the cockpit drains also serve as drains to the gas locker as that spills to the cockpit. If that filled with gas there is a possibility, albeit remote, that gas could get into cockpit lockers & hence down below.
When I had my gas safety check, the engineer told me it was now illegal to have a seacock on the gas locker drain. He got round this by opening the seacock on my drain and then removing the handle.
How far does the boat heel in a blow? Add some big waves, and I reckon that any openings below that level need seacocks. You'd be surprised how much water can overflow from a heads wash basin when it goes below the level of the water. I also managed to flood the boat when heeled over because I forgot to close the heads seacocks. There were a couple of inches of water in the cabin by the time I realised ?
I have to confess the cockpit drain locks were totally seized on Jissel, but I kept wooden plugs close by, and others got closed once a year, just to make sure they worked
I wonder what law he was quoting. Unless your boat is subject to inland waters regulations, I don't believe that there are any 'laws' about gas installation on leisure vessels in the UK. There is 'good practice' though...
Different for commercial coded boats where gas alarms and cut offs are required etc.
Many insurers have a view on this and some surveyors talk to a vessels insurers and some even send a copy of the survey report direct. You could have a problem if there was an incident that could have been caused by a closed drain.
Indeed. However it was the surveyor saying it was 'a legal obligation' that raised my hackles slightly. People airily quoting rules and laws that don't exist annoy me...
Ooooh - HUGE +1 for that!
I'm reminded of a surveyor who condemned the forestay attachment on a Snapdragon because it was fitted to the bow roller, and that was "just" bolted through the foredeck. The same way as has been done with no issues on all Snapdragons, but no, he wanted it to go through the bow.
Find another surveyor.
