saltyrob
Hi folks
The seacock on the inlet pipe supplying flushing water to the toilet is jammed shut, therefore have decided to replace it.As the skin fitting has a grill and is faired into the hull,I hope not disturb it, therefore would appreciate any advice on removing a the seacock from the skin fitting .I have replaced the seacock on the engine cooling inlet and ended up also replacing the skin fitting as the two would not come easily apart after approx 20 years service.
Many thanks
Rob
Many thanks
Rob
