Popski
Hi all.
First forgive me for repeating this post but I’m no further on since my previous post. My boat is a Beneteau Antares 30 fly and when underway For around 30 minitues or so I get around 1/2 liter of water in the starboard side of the lazaret. Previouly having had fitted a new trim tab considered that this was the problem and removed and re installed it. That didn’t work. Now my engineer thinks it might be from the transducer and speed wheel but I can not find the thru hull entry point and didn’t check its location prior to relaunching as I thought the trim tab would have cured the problem. I have attached a couple of photos where the sea water appears and I’m guessing when the boat is plaining the water runs from the drain hole. What I don’t know and determine is just where the water would be from. I’ve checked all hose clips etc and non found to be leaky. Would anyone know the track from the haunching where the drain hole is. Sorry to be long winded and any help would be well appreciated thanks. The Chanel in the pics is where the water accumulates and is there once we are back on berth. Never any water there when stationary.
